meh she isnt that good
You wouldn't hit that? Do you know how good she would look without that dress on? Neither do I, but I reckon it would be something special. Jimmies rustled.
LOLed at that pic.
Never said I wouldn't do her, because I would but gimme some of dis:
Emma Watson and Megan fox(the thumb) are definitely not from the same kettle of fish. I'd take Emma Watson over Megan fox any day.. Innocent bishes always look better
And yes extreme aero plane jelly for jimmy Fallon
Megan Fox, to me, is the girl you'd brag about having been with to your friends...whilst the actual personal enjoyment level would be quite low (dose thumbs). She's too hot and you're bored of her appearance because you've imagined her too much.
Emma Watson, I wouldn't have to tell anyone about that...it could be our little secret and I'd live happily for the rest of my life. I agree with the ginger
I thought I think to much into things lol
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
