man vs food...
burrito chalange (in knoxville)
burrito:
2 lbs pulled pork (900g)
1 lbs beans (450g)
1 lbs coleslaw (450g)
1/2 lbs cheese (220g)
4 full size tortilla
sides:
1/2 lbs mac'n'cheese (220g)
1/2 lbs bananna pudding (220g)
1 hour
that's a total of just over 5lbs (2.25kg)
never before complete (adam richmond was aparently the first to manage)
how ya reckon ya'd go dezz?
i reckon i could do it
It's disgusting but good show that.
They're not arriving :(
Seller canceled transaction on me cause out of stock. Everyone seems out of stock, wtf.
I've got 200x 5mg coming in, you want half of them? I'm fine with half that dose so I'll be cutting mine in half.
Bought a doberman puppy yesterday, won't be ready to come home till mid October, can't wait!
Pics when you can pick up him/her!
My dawg turned 1 last week, and he's still a rascal!
No need to project your own interests on to me, man! :whistling:
What would you suggest?
I'm no beer connoisseur though, just a simple guy, I just like what I like. Coronas, kirin, asahi, stellas, pure blondes, all good stuff imo. :yes:
generally speaking these are the cases i buy (i go through about 1 - 1.5 a week)
tiger
tsingtao
heineken (import only)
pacifico clara
cricketers arms
brooklyn larger
weihenstephaner krystal
erdinger krystal
yelkopopoviky kozel
wingwalker pale ale
murray's whale ale
kirin ichiban (japanese one only)
kronenberg (import)
bintang just makes me think of wanker straya kunt types wearing a bintabg tanktop in some form of desperate attempt to let people know they have been to indonesia
as grant said...
augustinerbrau helles = best beer ever
only available in bavaria tho :'(
Which is very upsetting.
Time to save up for another europe trip... Or a trip to America.
tiger
tsingtao
pacifico clara
cricketers arms
brooklyn larger
erdinger krystal
yelkopopoviky kozel
wingwalker pale ale
murray's whale ale
kronenberg (import)
Pfft you call those beers?
All I see is a list of water downed pilsners and pale ales :P
Get some scotch, dark, brown ales into you or IPA's if you like hops.
Lot of great micro breweries in Australia. No need to buy into the marketing of overseas companies.
Grand ridge, mornington brewery, white rabbit, Matilda bay etc
*all comments made tounge in cheek. Drink what ever the f*ck you want.
i can probably get it on the d/l but only in kegs and it will be expensive as aids medication
So it'd be cheaper for me to go to Germany and drink to my hearts content...
i f**king HATE 99% of Australian micro brewery beers....
they are all trying do over hopped IPA's and they just taste like a bunch of flowers (and all exactly the same with VERY few exceptions)
if anyone is falling to the trap of marketing (or attempting to look like there is no marketing) it's people that pay $70/case for aussie microbrewery beer ;)
want a heavier beer... hit up a 750 of chimay grand cru or a duval ;)
edit: to take a lil swing at pat :P
Edited by joeyjoejoejuniorshabadoo
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
