I'll kick your ass...
you probably will, but if someone else is paying. why not.
we should feed them to bums and watch the outcome.
on another note! i am so f**king sick of time wasters. i had one dude haggle me last night offering some stupid low amount and expect me to give him a roady worthy for that amount. then he comes and sees the car today, and say I would really like a car with a lot of space.
ITS A f**kING SILVIA
for f**kn f**k.
why the f**k waste my time you little flamin mongrel desease. f**k
lol Aaron, when i was selling my old car. This one guy said he'll come this day and time, confirmed with him again earlier that day then comes 30mins past the time no show. Contacted him and he said he's not coming..... rushed home, washed the car and even canceled my night.
The joy of time wasters!
Fk it's so annoying man. Seriously though he was after a big car, why even consider the 200 and waste my time to begin with. Slap the little f**k
Screwdriver the dream boats
Jonoe how much for your services? Can you make faded paint with lack of clearcoat look somewhat less unappealing?
More than you can afford pal.
I can do it. But it will only last 1 wash. Lol. And I'm not doing that. Too much labor for nothing.
I'll need to see the car irl to see what I can do :]
Smoke em..
Will hit you up once it's moving again.
Hottest thing I have ever eaten was a Thai jungle curry we made for staff meals at Mopho once... 40 green scud chilli's (thai chilli) per plate... It was the only time I have ever felt my stomach burning internally from chilli...
Would do again
On an unrelated note...
Snuck up on my fish last night (African cichlid tank) at like 4am... It was freaky! African Cichlids (particularly tangyanikans) are highly aggressive fish and are always fighting and playing chasey etc... They were all sleeping on the bottom in their caves... But they were actually lying on the substrate for the most part... One of them had even buried himself down inside the floor of a cave!
/csb
#fishlinesaustralia
/csb
#fishlinesaustralia
My axolotls used to dig tunnels everywhere in the tank it was rather funny. And I used to hand feed them, sometimes they would mistake my finger for food, they would bite your finger(no teeth felt like a suction cap) and would not let go.. You could drag them around the tank lol almost as if they enjoyed it..
/mycsb
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
