Haven't bought it yet... the guy's woeful grasp of English still haunts me
Yeah wait until you order and see how many emails you receive from him and how they are all set out and spelt, it's CRAZY!!!
However you saw the product and it's the best I've bought from anywhere
I look forward to taking one for a drive. I wouldn't be surprised if one ends up being my next car. What colour did you get?
It's funny I always hear from Skyline owners how long it takes for them to sell their car. Many of them told me not to sell it because it would take so long and have my time wasted by so many people. I sold mine in a month and got a good price :)
WRC Blue Mica - the Subaru exclusive colour (the Toyota twins exclusive colour is Orange.) IMO the best colour of the lot, I wasn't set on any other colours.
Re: my Skyline, it was hard for a number of reasons;
*Auto
*Turbo
*4 Door
*Highish (but genuine) km's
Limited my market considerably because most people want manual coupes with 'low kms' and a P Plater can't drive turbo. The first person to come and see it (after 4.5 months for sale) just lowballed me even though the car was as described and they had nothing to pick on. Second person brought all his mates, I let him test drive and he bought it. It was a good car, it just had to sell eventually. Frustrating thing was having 3x regos and 3x comprehensive insurances at once...
So the Roady passed everything...
But the guard lining?
Umm wtf?! He said just get the guard liners put in and he'll pass it. And he'll do the next Roady free?
Why wouldn't u just pass it? Lol
I think so, he said the only reason it's all passed is because its extremely neat and very well hidden ie gate and big turbo.
But for guard lining? Man it's such a waste of time, and one lining is $70
lol yup, its why im paranoid in rolling front guards...as wont be able to attach the guard liners back in lol
Negz, done a few front guards and kept the lining. Tony's one, jonoes two.. And a few others from the BMW forums aswell. And I got my linig back in too, just lost the passenger side so I have to source a new/used one
I lost one of mine coming out of the sweeper at winton and the other on the main straight at PI..
not like the attache too well in the first place, never realized it was a RWC thing tho..oh well.
Indeed it is, I had it pointed out to me too.
Good to know you can keep r34 ones... I may be a future potential client... maybe. xD.
Other costs coming up such as major ~_~
More so on ours as there's wires that run along the top rail and apparently "if the tyre pops and shreds the steel lining can rip through those wires"
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
