haha bunch of pansies.
try a car with black vinyl seats, chrome shifter and metal steering wheel, with no aircond..
all factory baby...
It doesn't count if you can't actually drive it...
it was on the road for 3 odd years, so I have a fair idea.
my first car had no aircond either.
85 subaru brumby, however it was a t top model,
so you pop the roofs off, wind down the windows and you were sorted in seconds.
plus the dodgy plastic they used in everything in it never changed temps.
evo's can be easily modded to approx 230awkw without having to worry about EPA's and VASS etc
i may cop a defect for wheels or low... but that's personal choice and in a clean ~2004 evo, fairly easy to get a roady
Knox TMU will still get you for having a factory turbo or using too shiny a wax.
yes, but i'm not worried about a standard defect... sure it's annoying but it's something that can be cleared easily
I think being a model citizen well dressed with a baby seat in the back will drastically reduce likelihood of a defect
Anyone who says the way you dress doesn't matter has never dressed well enough to experience the difference.
Fact. Like it or not.
this.
i dress smart/casual for work now since im always at a desk. and 9/10 customers walk straight up to me first lol.
so today im wearing shorts and a tshirt because im cranky when its too warm and yeah.
this...
200%
I'm guessing jacket would be unbearable in this heat that's why everyone's riding in singlets/tshirts?
Think I'll stick with car till it cools a bit
Wise or weak? Hmm
In other news, boat almost ready.
Edited by R-SPEC
Wise or weak? Hmm
I don't find this heat that bad for riding...with a vented textile jacket it's alright while you're moving. But I'm not jumping at going for a ride either...
40 degree days, I've ridden on one of them and, stopped at the lights is your own personal hell.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
