Should be free Sunday morning if you're into getting up early
No problem, thanks man hopefully I don't run into any troubles :) all depends how wide nt05s are!
on another note, moto gp on tonight! stoners last race (on a bike at least)
Come past when you get them fitted...wanna see dat traction.
that thing is gonna be a rocket ship with NT05's
Anything wrong with an 04 fireblade?
Workshop selling one good price tempting considering just trading in ma 2fiddy for it.
(Insert death/coffin joke here)
Speak to that Frank guy on TC, he seems to know Hondas. Always says you can't go wrong with 08 onwards for the blades
Lol nt05s
See you later diff lol
haha yep should be heaps better! I was getting 4.5s to 100 with gtech and huge spin surely into the 3s now, should be good from 2nd gear rolls now tyre diameter is about 1" fatter as well (245-35s bit skinny walled imo)
Lol nt05s
Usually input shaft will go first, but yeah I wont be launching it all the time I'll just roll out then punch it :P catches up pretty quickly to people
Wont be doing burnouts on these either at 375 a pop
Manuals are the ones breaking more stuff, CVs and tail shafts, clutches usually but yeah depends how you drive - dumping clutch on slicks starts to hurt stuff
Well they can't hand out defects for phaggotry
if the phaggotry consits of more than 5 people standing around multiple cars it constitues a hoon offence... so yeh... they can
VELCOME TO MELBOURNE JA!
Al said they cant hand out defects for phaggotry, you said they can.
The point wasnt about anything else, but phaggotry.
So....
How can they give you a defect for being a hoon(Phaggotry)?
:mrt:
they see you being a phaggot, and then decide to give you a defect because of the phaggotry
so they give you a defect for whatever they feel like to make it "legit"
pretty simple ;)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
