so I went past HWP and a booze bus last night....
turned the varex to "stock golf" and not a single f**k was given
did you pick the evo up already?
tell me about it... i'm starting to get a hard on for MY08/9 WRX sti hatches :/
lol wrx hatches.. is this what babies do to you?
yeh... chasers retuned it for me aswell... makes 172awkw with just a catback.. pretty happy with that, but i need the 200 club
aparently...
i think i'll look at one for the next car :O
what, you think you cant rip the handbreak in an awd?
havent you ever seen a rally?
or a ken block video
LOL I always did it going into my driveway, slight hill on gravel = 90degree slide
newb, i cruise past with no exhaust and no f**k's are given..... because golf
made 290 stock on chasers dyno too :P
before you guys say corners, give a falcon a open track (ie not deca)
1-Jan-2009 Ford FPV F6 113.80 1:53.80 Warren Luff "Dry
1-Jan-2009 Mitsubishi Mitsubishi Lancer Evo X 115.10 1:55.10 Warren Luff "Dry
and yeah Aaron making like 240 at <2000rpm :P
Edited by UNR33L
Yet the GT R-spec also driven by Warren Luff does the same time around Sydney motorpark as a 195kw Megane :P 2:18.50
Jokes brah. Your cars engine is awesome
yeah true definately need to swap out the shit boat suspension to coilovers, lower it and put some bigger dam tyres on it (245s really?) mine handles sick for such a big car now
obviously going to be limited though when you compare them to a properly designed sportscar, this is just a family sedan with a sweet ass engine :P
Edited by UNR33L
that hurts man..... not cool :'(
possibly... however he has 370
for some reason i thought simon wrote it lol..
well scott has 350kw.. i gave him a good run for his moneeeeyyyy
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
