Joined gym again today. Gotta stay committed woo.
Also, anyone know the legalities of pricing errors when shopping online?
If they (due to their error) have a lower price, and a customer purchases it at that, are they bound to honour that price? I mean they could easily 'sorry, it was a mistake, (a) pay proper price or (b) refund', I'm guessing? Or, yeah, do they have no actual recourse and should legally honour it?
Ethics of it aside :P
Leigh were you at Crown Poker last night?
Yes he was.
Strong mirin of himself in the toilet mirrors...
LOL as if I was, fixing my hair maybe - nohomo
but yes I was there, were you one of the drunk dudes hugging a dude peeing? lol
What gym you join?
Once a friend was betting online a clear favourite, must of been an error was $50 to 1, he put a couple of hundred on but ended up getting refunded the money back before the race started. I'd say they'd just refund you most likely unless it was a minor error.
What gym you join?
Dunno about betting but I thought if it's the advertised price then their liable for that, when I worked at K-Mart if a staff member had left an older cheaper price tag on the shelf then we were bound to honour it.
What gym you join?
Goodlife Wantirna (but can go to any of their branches, of course).
Haha, well I'd say the pricing error was fairly significant; Pierre Cardin suit... $9. I got six (LOL... 3 for my mate, 3 for me).
Basically there was a discount code meant to give you -$390... but the pricing was done at $399... so with discount, they all became $9 each.
Already paid/got an order receipt for it sorta thing I suppose, but don't know if the funds have been taken from my cc.
Yeah same as my work, we're bound to honour that as well.
Just wasn't sure on online pricing errors... wasn't really advertised I guess... but not my fault at the checkout it was a ridiculously low price haha. Hence wondering about the legalities :P
EDIT: I also know at Safeway or Coles (or both) if the scanned price at the register is wrong, you get it for free.
But yes. All light shed on this welcome :P
Edited by kaitoukid
You'll see me and Birds down there then :P
online might be different, what if they had bug or hacked etc? then some dude buys a shit load of what ever it is?
Matt did I see your car at sandown today?
Yah huh I was hanging around in Simon's bay, number 9, where were you?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
