amen brother.
I tell ya the shit I get away with when I had the Lexus or driving the audi now no chance in a import or modified commo such double standards but I guess people make it easy for them to target certain cars
So I thought having a stock standard Evo would stop all the cop troubles
Nek minnit, pulled over by 3 cop cars and about 7 officers
"This is a random check" "we thought your number plates were home made"
Dafuq?
Let go with a merry Christmas..
Excessive.
Yeh I they ran the plates, but he thought they were homemade for the better fit.
Like hamish said. Don't mind getting pulled over for an assumption, just nerve racking because u don't know whether you'll get a decent cop or a f**k knuckle.. And this time there were seven of them
rockin a baby seat in it ham?
not yet... will probably leave it until he is a little older and then we can have a seat in each car.
gonna try and find a recaro bucket that looks similar to the SR3's
I was out for a bike ride yesterday and got pulled over by one of those response vans, mate and i where like f**k, all this for no helmets?
Turns out the school got broken into though.
I Doubt they would pass Aus design rules.. Should get one that looks like it, and get it re stitched!
It's not too bad, they've dislodged one of the screws that goes into the chassis to hold it in place (if that makes sense). It hadn't prepped or sprayed either, and no real cosmetic damage. Zip tied it in place for the meantime. But still shit like that just pisses me off.
Realistically if I bumped a car that looked like it had a bar in prep waiting to be painted, I would leave a sorry note and that's about it. Can't expect him to repaint your bar for you when it doesn't even have paint on it nomsaiyan? Unlucky though man.
Yeah I get what you mean mate. Honestly like you said could have been much worse so I'm not that annoyed. Just annoys me that people aren't more careful around other peoples property.
Had Christmas lunch today with the old man's side today. So much food. Feel like I got a food baby in the old gut.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
