Just speak to the assessor, you aren't meant to but I remember doing it with the supra, ie sound system and all. He said just quickly do it and ill over look it, pulled out glass headlight full sound system hid rims lol was good
I mean worth a shot seeing as you just bought stuff for it, leave the manifold, it is a wreck itself lol
this is only really possible in a crash scenario unfortunately..
see how much they want for the wreck :/
So I see
Wreck Im assuming about $3k
Even then parts are worth more, don't think I cbf going through the whole parting out selling and sitting in your garage process.
If I bought it back it would be to fix it as a backyard job if it was viable. But probably won't do this
Hrmm I'll Ask tomorrow!
So I see
buy the wreck back, take what you want from it, put the stock parts back then do burnouts out the front of knox police station and they will tow it away for you
why minus the last bit....?
it's the perfect way out... get to keep parts, and car gets disoposed of for you.
of course there will be fines, fines, fines, impound and towing charges, fines, possibly a slight beating, fines and you will be forced to buy the car back later on anyway, loss of license, fines, possibly jail time and more fines....
apart from that it's the perfect crime
if you crasht the car you can strip it before you give it to the insurance company
if it's stolen and THEY find it, then you dont get to touch the car until the assessmemnt
you missed anal love.
you're a dick swinger, how can that be worse than ball handling?
Talent required for ball handling > dick swinging. I only have to stand there to impress people.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
