initially, until that got taken out for a neo
then that neo got exploded (before I got it)
rebuilt as a RB29 stroker, which was laggier than a RB25 and has also since exploded on the weekend (after about a month)
about a year between each of those sentences
fun times!
Yeah, I remember you had issues with DE+T.
How did you manage to kill few motors?
Just undo the bolt completely and pull the adjusting screws out, push the blade to one side and carefully take the blade out without scratching shit. Done.
yeah they easy to take off, also that's where you can adjust them for the downforce when take covers off
Vinyl wrapping it
if it's carbon your gay, better to buy a cf one
Dem 80km/h aerodynamics
Lol didn't you know I have my own wind tunnel? A fan with some flour..
not to mention dem spinouts on warm up laps at Sandown......thereifixedit...
Where have you been?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
