Yeh, or magnet.
f**k that M12 bolts straight through it. I'm going to find taxi side vinyls lol
I had a magnetic taxi sign that lit up through 12 volt / cigarette. Think it came from eBay.
Going up 30mm wider in tyre size (as all the ladies know, it's about the width) this year. Should be an even more wild ride than before :woot:
285 comes in 17s?
narz, have to get some 18's. 10 +25 looks possible at the moment.
Tell you what, I reckon a set of tri-spokes will look nuts on your silver bullet.
I cannot alter the guard other than "guard rolling". It's a 255 at the moment.
305 is massive, can only go up to 295. getting a 10.5 on the front is near impossible with the guard limitation.
Just whack bolt on flares and run 10 +19 tris.
Because you know Tris are awesome.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
