does he wear a bintang singlet?
Worse, Tiger Beer...because he's gone a little further than your average western tourist and wants people in the gym to know that.
fark you nick!
i was at costco when you were there... you spoke to me.... you didn't mention the f**king malteaster bunnies!
I saw them after I saw you, they were in the last few isles. Between the clothes and registers
where the chocolates are? weird... :P
i try not to go there.... it's the bad isle lol
Haha yeah me too, but Maggie wanted to buy some sweets for her parents when we go to Shanghai
Otherwise I would have missed them too :P
just get a membership man... you easily save the $60 and more on the first trip.
This $60 to go as much as you like for a year, and you do get some good savings
Also for all those interested the $170 alloy low profile jacks are back there as well
Tanganyikan cichlids - mostly between 5 - 10cm with about 1 fish per 12lt and weekly 20% changes.
tank is spotlessly clean
isn't 20% a little too much? 1 fish/12L is a very low stocking density.
especially when they're small
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
