Yep, not on standard injectors/pump
FIC's iirc, made in America where all the US evo's run e85 on them
Looks like I still have my reading comprehension skills :cool:
Maybe time to troll evolutionm and see if there's any such reports from the US as well then! Luckily (notrly) I have still around a year to research :(
Who cares about Evos anyway, we were talking Skylines and E85. You Evo boys take your 4 cylinder garbage out of here. Only milk and juice should come in 2 litres blah blah get out my country.
My skyline is 2ltrs :(
Might give it a miss on the ethanol tune. Will get a pulp tune first so then I will have 2maps to switch between.
LOL!
are you sure it's the injectors that are lean? all the evo guys run walbro's :P
Haha, nah this car was on a couple big bosch pumps
either way I don't really care what happens, was just letting you know and research into it before you just jump on e85 train and get 320.34355845984530845 kws at wheels dyno proven
Got a call from manager and their photo showed up whilst ringing. Found that odd as I didn't add any photo?
Turns out Facebook detected their mobile number and my iPhone showed their display pic. Also to add that I don't have them added on fb either.
So that means a long as you have someone's mobile number, you can find their Facebook profile automatically O_o
I'm not going e85 because e7 rods anyway...
8mr turbo and 230 ish then no more until e9
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
