lol... that probably "exists"
you would be surprised how often costco meat is used in restaurants
Yeh I get told that's the meat is great strangely enough.
Eh. Don't really want to try it..
and btw, i'm happy with 8+ might even be a 7, who the f**k cares.
lol, that's definately 8+ (more like a 9 on that bottom piece)
6 is a LOT less marbled
it's fine... I buy costco meat when i go there... cheap and better quality than coles/safeway but lower than a good butcher.
Generally i buy all my meat/fruit/veg/asiangrocerneeds from the Vic Market these days
I go once a week and spend approx $400 per month less than I used to at safeway, AND get waaaaay better food
yeah i know what you mean, but that was out of a vac pack that said wagyu f1 silver by stockyard, and that means 6-7
tbh i have no idea how they grade it without even being able to look inside.
if you want wagyu.. and i mean real wagyu be prepared to pay for it (think more than double their prices)
also I highly doubt anyone that works there can actually cook a steak properly considering the ones they used for their pics on the website aren't even decent
Well it was about $50 for the wagyu at Meet Wine and Co, should be looking at $100 for quality wagyu? Name and place please Sir!
They have x-ray vision.
my place. just pay for the beep. lol. no sauce, just salt and pepper. eat it and go.
ps, aaron still has some.
i'm guessing it's graded BEFORE it is packaged lol
An easy place to start is Rockpool... brilliant steak that is still decent size can be had for about $70-$90 and make sure you have it with the housemade harrissa - it's fkn epic
if you want true wagyu... as in david blackmores full blood...
the last place I had it was bistro vue and it was about $80-$90 ish for a 180gm rump cap... and it was worth every cent
hmmmm.... My missus birthday is coming up, might head to Rockpool.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
