LOL! Possibly. I'm reading about the Flex Fuel system. I think I might do it.
Honestly, I can't find a good reason you wouldn't do it.
Plug in Haltech with the Haltech e-content sensor.
Also allows you to pimp out the dash with with a racepak or something if you like :)
do it!
make you feel like your driving an f1 car :P
i just wrote up all the parts ive purchased in the last few weeks getting ready for my.. build? and im sure im forgetting parts or am missing parts i still want/need =/
do it!
Tell us! I just got my full 100k service parts for cheepcheep.
oh nice! yeah you would man! lucky :P
well the list ive got is ...
nismo cluster
nismo brake lines
nismo clutch line
nismo super coppermix twin plate clutch
moonface superlap tie rod ends
moonface superlap tie rods
cusco tension rods
cusco drag rods
cusco front arms
garrett -9s
hks actuators
apexi power fc & hand controller
hks extension kit
hks cam gears
dba 4000 T3 rear rotors
kudos 100k service kit
project mu b spec pads
ID1000's
nismo fuel pump
trust oil filter relocation kit
i think thats all ive purchased.. and i still need to get
rear + front swaybar links
rear d bushes
Edited by bluejeans
fuark, that must of been a big invoice lol
to be honest i dont know how much ive spent exactly.. but its been a few parts every week for a fair few weeks now..
just waiting for some parts from jesse streeter / some from perfectrun / and a few other from random places >,<
but yeah just hanging out to get it all done!
That feel when Santa delivers a package nearly daily...... hnnggg.
You better not be installing all that at Racepace :P It'll be sitting here for a week + with all THAT!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
