^ HD pics of crash, sad days, haha...
I see a camera... did footage survive? Still sucks though, man.
Fair enough. Still got some boyracer funtimes for me left heheh. SC V8 though will be naice. Have you actually been in Leigh's yet? Was that the turning point ahahah
Nah, not as yet, but always wanted a massive power blown V8 and with the second kid on the way, stepping up to a 5 star ANCAP falcon is always going to the a good idea.
To be honest i'd prefer to strapa PD blower to a VE SVZ and style it myself, but it will probably be the same or cheaper to go the legal GS route
back from gold coast after an epic weekend, all is good apart from when I smashed my head on the bottom of the pool diving in drunk, some hair fell out and sore / scabby now :(
do you have any idea how lucky you are? :0
2nd kid on the way aye! congrats! Yep 5star ANCAP ftw and always gonna be the cheaper option for a new car with PD V8 I do miss the turbo 'rush' feeling but PD V8 as a daily is awesome, cruise below <2k RPM and still miles ahead of people taking off at the lights lol
Yeah I kinda didn't think about it until I got home, could have been pretty screwed up if I had to go to hospital / knocked myself out or something - after it happened surprisingly didn't bleed that much which was good.
not pregnant yet... just know we will be doing it again in a couple of years :)
and i meant you could have been a wheelchair spaz, not just a bump on the head! be careful dude :)
None of that looks appetizing
then you gotta wait till east side steak night.
@ nick, steak night brah, and yes i gotta come view yo pussies. but i'll be working, so its bloody gay, unless you're avail on sat.
and speaking of steak, there's a cape grim porterhouse i've been dying to try. price though is comparable to rump cap. not sure if i should.
Aaron. We barely half way through. If u come now. Still tonnes of food!<br /><br />And there is no guinnea cops now!!!!<br /><br />Good wine hurr too. <br /><br />We just doing stuff bit by bit.
i do.. and i cant, already in bed.
i fkn hate you both. if he had told me 15 minutes earlier i wouldve been there!!!
better to spend your $$$ on cape grym ribeye and sous vide it
truestory
yeah steak night soon, I'll be east side this weekend for dyno day
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
