^ HD pics of crash, sad days, haha...
I see a camera... did footage survive? Still sucks though, man.
Fair enough. Still got some boyracer funtimes for me left heheh. SC V8 though will be naice. Have you actually been in Leigh's yet? Was that the turning point ahahah
Nah, not as yet, but always wanted a massive power blown V8 and with the second kid on the way, stepping up to a 5 star ANCAP falcon is always going to the a good idea.
To be honest i'd prefer to strapa PD blower to a VE SVZ and style it myself, but it will probably be the same or cheaper to go the legal GS route
back from gold coast after an epic weekend, all is good apart from when I smashed my head on the bottom of the pool diving in drunk, some hair fell out and sore / scabby now :(
do you have any idea how lucky you are? :0
2nd kid on the way aye! congrats! Yep 5star ANCAP ftw and always gonna be the cheaper option for a new car with PD V8 I do miss the turbo 'rush' feeling but PD V8 as a daily is awesome, cruise below <2k RPM and still miles ahead of people taking off at the lights lol
Yeah I kinda didn't think about it until I got home, could have been pretty screwed up if I had to go to hospital / knocked myself out or something - after it happened surprisingly didn't bleed that much which was good.
not pregnant yet... just know we will be doing it again in a couple of years :)
and i meant you could have been a wheelchair spaz, not just a bump on the head! be careful dude :)
None of that looks appetizing
then you gotta wait till east side steak night.
@ nick, steak night brah, and yes i gotta come view yo pussies. but i'll be working, so its bloody gay, unless you're avail on sat.
and speaking of steak, there's a cape grim porterhouse i've been dying to try. price though is comparable to rump cap. not sure if i should.
Aaron. We barely half way through. If u come now. Still tonnes of food!<br /><br />And there is no guinnea cops now!!!!<br /><br />Good wine hurr too. <br /><br />We just doing stuff bit by bit.
i do.. and i cant, already in bed.
i fkn hate you both. if he had told me 15 minutes earlier i wouldve been there!!!
better to spend your $$$ on cape grym ribeye and sous vide it
truestory
yeah steak night soon, I'll be east side this weekend for dyno day
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
