kynoch, can you do me a favour? i need the amayama links for
timing belt
water pump
cam and front crank seal
tensioner bearing spring
idler bearing
tensioner bearing
or pretty much the kudos kit.
Michael you wouldn't know the difference between the R33 and R34 complete engine gasket kit is would you?
I've ordered a complete gasket kit for my Neo engine via High Octane. they supplied a normal 25det kit ensuring me it would be a fit.
Already know the plenum gasket is different
What times everyone going to 100mm tomorrow? Make a south east cruise up?
What time does it start?
I was planning to go maybe just before lunch, look at cars then eat then go home and get ready to par tay
@HSV
meh. ugly too.
"has technology similar to this car" "has numbers bigger than that car". Are they trying to increase their international market? its a bit late for that. Unless they plan on pumping out more of these than SS'. Though the more they make, the longer it will take to increase re-sale again (20+ years already for most HSVs)
@100mm
is it worth driving in? would rather catch train tbh. Driving through the city is bad enough, let alone driving into the city
That's what I was thinking. Say get there midday -1ish have lunch, look at cars. Then home..
@100mm
Driving to the city is easy. its only bad during peak hour
Sounds good. Pretty sure Pat in his new beast will drive down with us
No worries. Did one of you want me to pick up up? Avoid everyone having to pay for parking..
Maybe! I'll msg ya tonight. Thanks bru
if you wanna wake me up, i dont mind.
I'll call you to wake up
Or Aaron and I will come past and knock on your bedroom window
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
