Yeah like first gear controlled throttle, can't go anywhere near full front comes up way too far did a massive power wheelie the other day pooped myself.
then like 2nd 3rd 4th full revved out fark that adrenaline when there's no one on the eastern linked up private road.
Dezzmang, yes it's puig and there isn't really a gap, maybe a tiny gap like 1mm,
Rode to st kilda last night, fuark eastlink cold on way home at 12am
Sweet thanks, think my mate has Puig or ZG so I'll sus his out next time I ride with him if I remember.
hmm you'll have to show me this road once i get my bike ;)
although i will be happy even reaching 100 with stability on a two fiddy :P
Mates duke 200 limited at 135 I think lol
For learners anyway so no f**ks given they should be learning low speed / traffic stuff anyway :)
Duke 390 would be mad learner bike. 44hp and 150kg wet
Edited by UNR33L
Learner sports bikes rip up the corners anyway and that's where half the thrill of riding bikes is. Through tight passages they can be quicker than 600s and superbikes, particularly in the hands of amateurs.
Phillip Island and a couple of other high speed tracks are the only tracks that reward the bigger bikes. Even at PI with a massive straight and sweeping corners, there's only about 3 seconds a lap between a professionally driven 1000 and a 600, then another 4-5 seconds for the 250s.
lol you gotta come out riding with my mate...he rides a neglected Ninja 250R, with a rear tyre that has no tread in it...he hangs off the thing in the corners like he's sitting in a side car and he absolutely kicks my ass.
^COT DAYUM indeed...
Only wheelies I see myself pulling are in Mario Kart...
Think I've got my "first choices" in gear sorted! Gonna go see how they all fit though at Peter Stevens tomorrow! ... Then order online bwahahaha.
edit: just got back from gym, sitting here with me proposed 4-day weekend (self-made). feelsgoodman.jpg
until i have to work and do assignments on the real weekend, anyway :P
You may end up ordering from Peter Stevens of you're buying a lot of stuff and some is on sale. My gear from there was only $100 more expensive all up than online, worth it given you can take it back there for faults and don't have to wait for shipping.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
