only made 285rwkw.. looks like lots of money (and time) spent for that lol pretty awesome tho
not really...
it's 285 on that wrecker motor which is temporary... it's just testing it.. he has another motor which it's all going onto and will be tuned more agressively...
trent is guessing mid 300's....
which i'm afraid son... in a 1300 odd kg VN / VP commo... will place your 370rwkw squarely in his rear view mirror :P
1300kg is still light for mid-300kws in my books lol.
that was my point
do you know much about how its setup? ie. supercharger covers mid-range and then turbo tops it off?
supercharger only for bottom end
turbo takes over when it hits full boost.
haven't seen the graph yet but it's hitting 20psi by 2600 revs so will be a crazy crazy motor
Get the slix..they look half decent when you're off the bike
I'll be getting a pair soon to replace the plain blue ones I got
Yup, think I will.
In other news, ACQUIRED BIKE LICENSE* !!
*Really it's still just a permit :P
Had a ball today though, good fun.
not really...
True, light car I wonder what sort of torque figures that thing puts out would need some fat rubber to keep it under control
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
