Yup been through a full EPA. Do not want again.
Part of the EVO choice... 230awkw can be EPA passable with just a catback change
Only thing other than that would be the fuel pump and I would be willing to take my chances on that one
that's cute :P
gotta love 370rwkw with no mods :D
y'all just gaters
Alex you're right though won't be many GSs like mine around, hell even now there isn't many around.
Few more GTs ( 5.0l 335 i mean) around than GS's but still not that many, I never see em
Edited by UNR33L
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
