Maybe my area is also still 147 (-4c)... Think dad just got home, maybe he saw. *goes to check*.
In other news, got a grade that was lower than I expected for one of my units. I was certain I should HD it, lols. Email lecturer etc, turns out some error in their spreadsheet wasn't taking into account one of my assignments...
So if I hadn't thought something was odd, and taken initiative, this wouldn't have been fixed, I would've had a lower grade and shit, no-one the wiser... Can not trust the system at all these days...
Well as it turns out, it WAS indeed an HD, so :P
Depends on the subjects. Arts I expect nothing less than HD's, Eng I try to maintain at least D's. So they don't write me off without an interview or something :'(
Yet end up being so lazy in-semester. Every semester will "be different"... but nope hahaha.
I have 16 cent / litre vouchers muhahaha
If anyone in eastern suburbs wants a 10 cent / litre voucher, I have a few of them too.
Yeah i got a 17c one from woolworths the other night. Something is going on.....maybe the supermarket petrol retailers using the price per barrel hike as an opportunity to try squeeze a few more independents with these tasty discount vouchers.
>spends $5 fuel driving to birds for 10c voucher
>saves $3.37 at petrol station
>profit!
Except he lives close enough on the way to places that it's the other way around, at least :P
I think I live slightly closer than from yours even, judging by last time direction when he said he dropped by yours when he dropped off my bike :P
haha was just guessing, no actual math done (slow day too) - then again my car is sitting on 16l/100 i suppose.
I live about 8 minutes from Birds I'd say.. I live in dat dere Wantirna / Knox danger area hence me not owning a skyline
Thinking gym > kebabs tonight..
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
