Progressive Tiens suck balls, had them in the s14 to start with, crashed though all the bumps on the street, then got all rolly on the track, worst of both worlds.
Compared Tiens with Kings? I'd be interested to know your opinions of each if so...
hey nick,
the XXR 527's in 18x9.75+20 that you had what did you need to fit them when you had the tien progressive springs?
i'm thinking im gonna go same same... $800 you cant go wrong lol
also i'm thinking 245/40/18
I ran 17s on the XXRs, 17x9.75 +24 iirc and had 255/40
sup
is it just me or does every evo 8 have a different shade rear bar?
ive looked at so many and i think in all of them, the rear bar is a different tinge/shade compared to the rear quater panels
surely not all of them have had touch up / spray work ?
bumpers are always a different shade as it's plastic compared to metal, and there is something with the paint when it is applying so the shade is always off a little
Hmm... Tiens it is then :P
Srsly tho... Whatever I find cheapest hahaha
I had teins, they were ok. But I would just spend the money and go BC coils, there could be a chance you get knocking front struts like I did. Iirc it was pretty common in 7s
I'd say so, look the best on the ct chassis
true, have seen a few with these. i like the 521's a bit, i think.
or maybe some varrstoens.
or i'm thinking some rpf01 in 9.5 +15 in SBC... delicious.
show and shine is in feb, 15th I think, Como park booked out till then.
for the S14 cracked it and went straight to Coil overs.
Had white line in the BB b4 it and they were bearable, pretty stiff and sagged a bit but was mainly looking for drop so that was fine.
Kings in the ute (well the front) and they seem quite nice to daily drive on. way too soft for track tho.
shout-out to an old member #@M34N ?
anyone know steve personally? had a R34 and a V36. hasnt posted since 2012. Used to work with the guy, havent seen him since like 2009 or something.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
