lololol.
Decided to go with E-tuner/Edge for final tune on Pulsar. didnt know he'd done a PGA members ride as well for a mean 290kW on 98. Will get Ace dyno/workshop to do run-in tune as he's a good guy and is local.
wew.
i'm not saying anything negative OR positive here in regards to E Tuner... just stating a fact
but the ONLY reviews I have EVER heard about him is how he was able to get so much more power than the previous tuner
_________________________
read here
Lunch... hungry... Want another Mexican Parma from last night.... Cheese and Salsa and Jalapenos... it was like an orgasm in my mouth and everyone was invited.
aka... Mohsen's Saturday nights
read here
more interested in the curves than peaks/values. but its a fair point, I have noticed that most advertised clients are big power... but then again, how else does a tuner advertise and pull customers?
As long as it isnt too rich/lean, cold start, decent idle and fuel consumption. That and proficient in most common standalone ECU types.
yeee get that fixed lol.
meanwhile on the topic of silvia's for sale, what in the actual f**k is this http://www.carsales.com.au/private/details/Nissan-Silvia-1994/SSE-AD-2256589/?Cr=22&sdmvc=1
when I used to work at autobarn I had a few Etuner customers and they all said the same thing
"I took my car to x, y and z and it made 200kw but then i went to E and it made 350... he's amazing"
do i really have to explain this further?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
