Noticed the amount of stealing today... :-/
lol, so its just an expo showcasing them cake decoration skillz?
Yes.... thought that there would be lots of cake tasting but it's pretty much like one of those noodle/suzuki market but with cake/cupcakes.....
/disappointed.
two stolen 34's, one smashed up and abandoned 34 sedan and that 32 stolen all in one day wtf. o.O
When mine gets nabbed, I think I'll buy another bike... 2004 ZX10R maybe. With a Skyline it's a matter of when, not if :unsure:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
