Duly noted, thank you peeps. And thanks for the butter recipe Ham. Omelettes are badass and their simplicity and low mess make them win at life. My omelettes are so busy I have to use a handful of cheese as a binding agent or it goes Hindenburg on me...
Would love to add vegetables for texture, but I don't want to mess with my all meat tastes. Parsley as a pub meal garnish is as far as I would go!
the humanity
Waxed bonnet, then cbfed the rest of the car so now I have a nice smooth bonnet but nothing else :D
Dat arm / shoulder workout rubbing that bitch off
Edited by UNR33L
Yuck what for?
was driving normally 5th gear doing about 70-75 in a 80 zone coming back home from work literally 2 mins away from home yellow one pops up out of nowhere tailgaits me puts the lights on and shit. Partner was a good bloke but main guy was pretty rude. He warned me for my rear licence plate for being bent and unable to read from a 45 deg angle. Got a fine for driving manual on auto licence (my fault for not booking my test sooner so not complaining left my car at site and walked home) but also for "failing to display p-plate rear" even though it was up and on factory uv cut tint that has passed Rwc he said he couldn't see it and gave me a fine and 3 points....I was on 1 point before this so licence is bye bye unless I contest. :(
I got done for the EXACT same thing.
It would of been 4+ years ago, on my P's in my N/A R33 just when green P's were just introduced.
Pulled over - done for manual with auto license (had the re-test booked but you know vicroads delay and what not, fair enough $150 and my fault) Then also said P plates not displayed cos you couldn't really see them that well through the tint, and with water on the rear window. $150 and 3 points for that as well, I wrote a letter to Vic faggotpolicegayflamin mongrels and got out of the P plate thing. From then had to display them on outside of car with magnetic P plate on the back which were sometimes taken but meh.. got through my Ps eventually.
Then got a 33r off Ps, random EPA etc in the mail and just had enough in general sold up and got a ford, buy a ford. inb4grant
No points at guessing which flamin mongrel pulled me over ;)
Edited by UNR33L
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
