You know where the cool restaurants are at home, though. Food is subjective...I've loved all the places we've eaten at...cept maybe one. Most of the world eats meat; I doubt catering to everyone's taste is even a criterion in earning a chefs hat. Hell I don't like some of the food served at some very reputable places and wouldn't even eat it but I wouldn't say the place is shit when I haven't / can't even eat the mainstay of their food/menu that they are famous for.
So go home...
Yeh amg c63 under a ton is do able but it'll have high kms
The a45 is awesome don't judge it from outside the interior is better then the c63!
I know of heaps of people with audi trouble man
There's no way in hell I'm spending $80k on a car I don't like the exterior of...
lol bikes exacerbate them. Do deadlifts; strengthen back; ride without ever getting a sore back. What'd ya do to it anyway?
No idea, ongoing problem. Have tried several strengthening things, deadlifts, medx (fancy back machine). Comes and goes. Scans show a couple of bulging discs then sometimes pinch on nerves
If they are some of the best restaurants in the world then they will cater for everyone.
One of the best things about owning/running one of the best restaurants in the world is that you don't actually have to cater for annoying-ass vegetarians or stupid requests
Will they do me a well done eye :P
Actually ate at Ash's Squires Loft lastnight...food was very good. CAAB angus porterhouse was very tasty and a good size (400gm) for the money. And shock horror I had it done medium :O
I asked for "medium rare" eye fillet the other day and seemed to come out pretty well done :\ didn't really bother me as it was a company expense but still! should of said rare!
Edited by UNR33L
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
