lol you wanted varstoooeooeneoneoneonens which are fakes. lol
Hahaha
Besides, those are only 8.5" wide. I mean, where do you expect me to buy tyres for it? The wheelbarrow section at Bunnings?
maths is wrong
True, but blah blah has a point ;)
Hmmm I'm very interested but jsut wondering how the +30 will look on the front.
or you could get these like every other phaggot with a commodore
americantiredepot_dc66_22x9-1310-763-00-
Haha f**k that, I don't suck THAT much dick hahaha
isnt that like an extra 18mm of poke tho?
use this.
http://www.willtheyfit.com/
post results.
I see this rim on so many cars
Not sure why the owners think they look good
Same, looks like puss.
or of course the ultimate commodore rim:
LMFAO!! By far THE worst wheel in history. Would rather square wheels than them ugly things.
There was a dude on one of the commodore forums with them and not even a flamesuit could've stopped the guy from melting haha
use this.
post results.
http://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=20&wheelwidth=8.5&offset=42&width2=275&aspect2=35&diameter2=19&wheelwidth2=9.5&offset2=30
COULD be a good fit, but the current fronts on mine sit pretty good with no scrubbage. Not sure if +30 is overkill for the fronts
brooooooo.
300300000Incubus-500-Paranormal-Black.jp
These rims SUCK! You're not helping at all mate!! :domokun: LOOOL
itll be a great fit, just run a tiny bit of stretch and some negative camber. do it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
