What happened?
He plastered as?
yeah bit. had a paddle pop in his mouth, made him drink a warm cider: mentors/coke effect. semi-puked on ground. then Simon poured his drink on him (wtf Simon). he stood up with phone and slipped out of his hand. feel flat on screen. farked.
Damn, should've stayed, stupid family.
in other developments I washed the evo for the 3rd time since owning it.... I even clayed it!
shit it looks a lot nicer when it's clean lol
might wax it tomorrow, most likely won't... I think the initiative has gone :/
  • Like 1
Went for a drive in the Ralliart, pretty decent fun. Dct is definitely better than standard auto. Shifting at carpark speeds is a bit harsh though.
Titan, do you know what the big black box attached to the windscreen is (assuming its stock)?
the 2010+ cars are better at that, they changed something which made them nicer, last i heard they were looking to see if you could flash the older boxes with the newer software.
box attached to the windscreen? up near the rear view mirror? auto lights and wipers.
I've washed the 34 3 times since owning it... Might wash it sometime soon
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
