Oh hai...
Car is all done.... again :D
Drivers side Recaro installed.
Passenger side Recaro still needs a rail.
Installed Mike's old auto trans cooler in the factory spot as a power steering fluid cooler to upgrade from the Loop thing in front of the drivers wheel.
Replaced orange indicators with clear ones which were thrown in with the front bar I bought, he clearly didn't know what they're worth.
Oil Change
Great success.
Also, sold my stock 33 turbo... Had the price very roughly set, guy travels for like 45 minutes to my place to inspect it and then he starts ummming and aarring about shaft play and how he doesn't know if it's worth it...classic bargining move, then right off the bat he offers me $5 less than my asking price :| Professional haggler right there :|
Oh hai...
Oil Change
Great success.
Well done SIMON.
Shit I'd completely forgotten about my southern cross tramp stamp, it's still kind there surprisingly.
Tramp stamp?
Shouldn't have left the party...
Yeah I didn't say anything, but you were flashing the goods when you were trying to get the PS Hose off and leaning down into the engine bay... Think the turbo buyer's mate was a bit keen when he spotted it
I scrubbed the crap out of mine in the shower with a nail brush, I'm still pink
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
