Oh hai...
Car is all done.... again :D
Drivers side Recaro installed.
Passenger side Recaro still needs a rail.
Installed Mike's old auto trans cooler in the factory spot as a power steering fluid cooler to upgrade from the Loop thing in front of the drivers wheel.
Replaced orange indicators with clear ones which were thrown in with the front bar I bought, he clearly didn't know what they're worth.
Oil Change
Great success.
Also, sold my stock 33 turbo... Had the price very roughly set, guy travels for like 45 minutes to my place to inspect it and then he starts ummming and aarring about shaft play and how he doesn't know if it's worth it...classic bargining move, then right off the bat he offers me $5 less than my asking price :| Professional haggler right there :|
Oh hai...
Oil Change
Great success.
Well done SIMON.
Shit I'd completely forgotten about my southern cross tramp stamp, it's still kind there surprisingly.
Tramp stamp?
Shouldn't have left the party...
Yeah I didn't say anything, but you were flashing the goods when you were trying to get the PS Hose off and leaning down into the engine bay... Think the turbo buyer's mate was a bit keen when he spotted it
I scrubbed the crap out of mine in the shower with a nail brush, I'm still pink
