Ma Nigga
No wedding for me. No kids either
Just $$$$$$$
666e8b064728e9605e3fd677083ab3ea87bc6727
You got a house to yourself yeah? you best be making a 'games' room with a big ass pool table, bar, etc.
Edited by UNR33L
  • Like 1
Ma Nigga
Just $$$$$$$
do you wonder if life may be unfulfilling without family / kids etc?
not having a crack just curious
i mean i never thought i'd have or want kids etc but i dunno the older i get i think it would seem a bit pointless
Edited by alr33x
ditto.
but fark marriage. de facto all up in here
once i found out youre supposed to get an engagement ring AND a wedding ring... it was the nail in the coffin
Got a poker room but rarely play these days
The way I see it I'm too f**ked up to be in a relationship and definitely not a good candidate to be a father. It's not really a choice just the way it is, so no choice but to accept it and get over it. I'll just have to find other ways to make it fulfilling, most likely with material possessions
Kid I went to tafe with had a VL, got a small branch caught underneath it and it fell out just as he went around the corner then stopped to investigate. Watched him poking around down there for like 10 minutes before I put him out of his misery :P.
its still run in.
we'll see what happens with new turbo. will probably rev limit at 7800 or something, wont be much torque up that end but cams will probably be still going.
but used to be
I used to think same... but EOTD it's something you will want eventually as we are all programmed for it.
after all it's the ONLY reason we exist.
In my mid 30's now i am starting to see a lot of my mates without kids starting to say they wish they one after hanging out with Orlando
Orlando is pretty fkn Rad though
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
