Not my kids. When they are old enough to use their hands and legs, they will be earning that iPad so that they actually give a f**k if it gets scratched up and can parade it around proudly as a trophy of their achievement. I like to think our generation (soon to be parents) are looking on the current generation of kids and realising where their parents (the generation just above us) f**ked up big time. We can still save the future!
  • Like 1
Funnily enough was having this conversation this morning, one of the primary schools my niece goes to "requires" you to have an ipad. Same with another co worker.
I'm like u wot m8? So they can sit at the back of the class and play Angry Birds :/
i don't think I have ever agreed with you more in my life
Why not ride in, Leigh?
Thought about that, but when you gotta wear in slacks and a shirt tucked in gets a bit annoying / messy. The extra time you gain almost not work the effort cos you spend time getting ready at work again.
Then you got the sweaty pits etc on the hotter days.
I used to work in Richmond and hated it, so if I go city center might hate it more hah.
But all the ladies in their mini skirts won't be mirin' if they don't see that muscly guy ride in on dat motorbike
Dat alpha bad boy image
Lol I must admit in the city today I was thinking c0t dayum at some of the ladies.
I swear some of them dress up like they're going OUT and not for work hah.
haha spades a spade my man! aint none of these fancy dressed women living the dream at reception
Never hurts to dress sharply though, even if you're just a glorified PA. Nothing worse than a girl who puts no effort into her appearance
