Naw mang as awesome as C63 AMGs are you got a nice new car already that you know history of 100% and its all YOURS! dat new car feel.
but it aint no BAWS v8.. hrmm
Edited by UNR33L
yearh man c63 is epic but this year is shapin up as too expensive already renovations & honeymoon + wedding = forget about it lol
Buy c63, sell the audi?
33 gtst going for 4k in drift sales andy.
Nahhh, even though cheap as chips,, I've already ahd my time with a R33 GTS-t. no point buying another one that needs more work to get to the same "happy" level that was the old R33JET haha
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
