Naw mang as awesome as C63 AMGs are you got a nice new car already that you know history of 100% and its all YOURS! dat new car feel.
but it aint no BAWS v8.. hrmm
Edited by UNR33L
yearh man c63 is epic but this year is shapin up as too expensive already renovations & honeymoon + wedding = forget about it lol
Buy c63, sell the audi?
33 gtst going for 4k in drift sales andy.
Nahhh, even though cheap as chips,, I've already ahd my time with a R33 GTS-t. no point buying another one that needs more work to get to the same "happy" level that was the old R33JET haha
