Go to a baseball match
preferably Yankees
NY go up the top of the rock, better view than Empire plus you can get pics of empire plus no crowds/lines
topoftherocknyc.com
eat white castle.
sure not the best food in the world but damn I love that film.
eat hotdogs from a cart
avoid olive garden, bubba gump, blah blah blah
go to hells kitchen and eat instead
how you finding the ute dezz? can you fit the bike in the back??
Goes good, bitch to park coz u cant see shit especially with the hard lid, but I'll get a reverse camera to fix that.
You can fit the bike, on an angle and the gate will close, or straight and the gate will be open a touch. Was easier borrowing my mates trailer for PI today as I was the only one going, and cbf taking the hard lid off...
Thinking i'll just buy a trailer if one comes up for the right price...
And I think its time for a new laptop...this one has been falling apart for a while after I dropped it...but it was manageable..now the I is f**ked...didn't realize how often you use I when typing until having to smash it down for it to work...
preferably Yankees
topoftherocknyc.com
eat white castle.
nice! some good suggestions will be sure to check them out.
keen for a lot of their food places actually, want to check out Dennys
ah yeh that's good you got a mate with a bike trailer how hard is track riding? been thinking about it for a bit but would suck if I came off and binned my new bike lol
do you use laptop for work? should get like a toughbook or something and claim it on tax?
if not you can replace keyboards in about 5 minutes depending on the laptop too
Edited by UNR33L
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
