This, during the week at night at least the top carparks are empty
lol I was kidding. unless you really do want to see vampire academy....
lets do kebabs tomorrow night. impromptu meet. free pulsar shotguns for all!
wednesday night?!?!? im down. ill bring the micra.....
does micra get wheelspin now? hows it running?
sweet as a nut mate.
and yes, even with fat (for a micra) bridgestone grids on the front it lays down some 11's..... didnt before the solid mounts!
just drove it to work this morning. and for a 300,000km engine im impressed. few rattles and what not from the cab, but overall i gotta say nissan uk did a great job.....
timing chain is a little noisy, but nothing i cant live with.
needs more GTX
http://www.skylinesaustralia.com/forums/topic/440875-fs-garrett-gtx4708r-turbo/
f**king lol.
doesnt even have gtr turbs yet.
need a few more bits, and momo needs to send me some f**king oil and water lines the kent.
gonna go see scotty tomorrrow after work about a nice cat back.... if hes in...
Depending on time/locale; might drop by impromptu kebab meet.
Coupe doors are pretty awesome for actually getting bulky-ish stuff in, so skylines being spacious not altogether untrue :P
Haha I can also confirm there was some talent there!
I don't think Dyno day is happening any time soon afaik (though it was meant to be this month as per calendar)
Unfortunately not :down:
All the workshops asked were busy.
haha not Vampire Academy of course, but some other movie
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
