$600 fair price for HKS super dragger to suit evo 8 ?
I've seen Apexi N1s go for like $250 in gc
However I've got a really good mate that does exhausts that would be able to build you a killer one for cheap, flow well and sound good to
He is is Roxy too
its the factory FQ exhaust (hks superdragger) as the car has an nvidia on it
so the hks one is just sitting in the garage, thinking of selling to free up space as im not using it
maybe ill do like $200 on ebay and let it go for whatever it sells for
Do that....
Martin travelled a lot
Mohsen finished his car.... It broke... He fixed it... It broke again... He fixed it... It got backed into... He fixed it... It caught fire... He fixed it.
He then bought a jetski in the middle of winter and is now trying unsuccessfully to sell it.
I am having a second child
Alex bought an a5, discovered all euro cars suck as sold it to buy a Nissan SUV
Paul bought an FQ340 but never drove it because he was too busy f**king with the ECU
Alvin got keyed again, he then got defected for his spoiler stays being too pointy and was fair butthurt.
Birds was just birds, but he started banging leesh. He is still birds.
Nick bought a crown and is VIP stylin
Artz bought 2 cressidas and is putting a 1j in one of them
Scotty fabbed things for people.
Ay-ay-Ron sold his s14, it was then destroyed by some doichebag
I sold my 33, it was also destroyed by some doichebag
Ric stared work at the ATO
Tony's car was stolen and destroyed.
He bought back the wreck and turned it into a ducking monster
R34 GTR meets need security now
Grant bought and sold a bunch of cars including a GTR that he had previously owned then had a sook about life
  • Like 1
Dezz got more into bikes and started racing them... He is still alive, and more tattooed
DR Drez became Our first billionaire
VWLYMCMB was formed
Pat f**ked off to WA for some mining job and got 7 final inspection details
  • Like 2
VWLYMCMB was formed
Jonoe became a Honda fag
Haha wow thanks for the great re-cap and congrats on the new kid on the way :)
Ive seen Mohsen's non stop trouble with that thing. glad to hear everyone is all good then. What's with needing security for R34gtr's? are they being stolen more often now?
No one cares but my re-cap is as follows:
-BMW M3 was the biggest money pit known to mankind
-Im now driving a C43 AMG ( pics soon) and its built like a tank.
-finished my diploma in project management
- went through a very rough patch but im on the other side of it now and back on here (obviously).
- plus im an Uncle now :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
