I nearly booked some flights yesterday, till realized it 55$ for a ticket for WTAC.
so think will pull hubs off S14 instead.
Im assuming flights would be waivered? $55 almost gets 2 people into calder park to watch drags for a few hours :rolleyes:
Not sure if should spend my flyer points on free flights or business upgrade
Seem to get more "cash value" from doing the business upgrade if you calculate the costs of paying for either in real money
Don't have enough points for the little mongrel girl to get her way
Martin, I thought as much...might give business a go so I can tell Pat it's not worth it on an empty A330 Perth flight
  • Like 1
125 for 4 days at bathurst, 55 for one day of WTAC..
it's an armature event with massive entry fees was expecting 20-30 entry.
and yeah flights were on points so free.
But what about watch drift and show n shine? All the vendors and garages... I reckon itd be worth it.
At least cheer richo on. For shame.
You'd miss an event you wanted to go to over $25?
if I go have to take partner as well, and just turns into an expensive day trip
more so when we have Fiji in a couple of weeks and a house move as well.
plus having a weekend at home for first time in over a month is a nice idea.
Free market will dictate what the event is worth...if people think it's worth it they'll go and the event will keep running...if not they'll shut up shop as the numbers dwindle over the years.
Which is pretty much what happened to autosalon. Does anyone remember autosalon? Yeah, I bet you do.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
