AC 7260
I googled it while trying to fix it and it's obviously a VERY common problem to the point where msi are literally robbing people for the money they're charging for it.
How can a f**king high end gaming laptop have such bad wifi
The thing is f**kin useless to me now
hrm did you see this thread?
http://forums.whirlpool.net.au/archive/2241695
definitely looks like a driver issue, i'd be trying to find some of the older ones - or this
I just got these cards yesterday for a new-build laptop (Toshiba P75)
Initially I used the latest Intel drivers (17.x) and performance is 2.5 Mbyte/sec range which is terrible.
I uninstalled the drivers and it went back to the stock one in Win 8.1. Now getting 25 Mbyte/sec up and 23 Mbyte/sec down at close range. Pretty much the fastest I've ever seen on my WLAN at home.
Edited by UNR33L
I'll sus it out tonight... Was reading Intel forum this morning and it seems like it's a long running issue which Intel aren't solving in any of their new driver updates... If I can't fix it I've basically blown $2600...
inb4 should've bought a 15" retina display macbook
  • Like 1
Would've been better than this thing.
The laptop itself is fine but why a company as big as Intel would continue producing a known piece of shit wireless card, and why companies keep putting it in their systems is beyond me
What model laptop is it? Do you know if the wireless card can be changed over?
Msi gs60 ghost pro 3k
Sounded like it was the sort of laptop that can't really be modified /altered too much...
Shouldn't have to change shit just to be able to use the fkin internet on a $2600 laptop... It's 2014 ffs
You should be able to change it over to another card looking at the type of laptop it is, I can't find any disassembly guides for it though so can't confirm that. Unfortunately MSI aren't known for their quality control, for a gaming PC on that budget I would have recommended an Asus.
every mother f**ker in here was reccomending MSI... I'd never even heard of them til everyone brought it up, knew I should've went with what I know
Although so far the laptop itself is fine, it's just the piece of shit wifi card, which is intel.
If I sit next to my router I can get proper speed, but what's the f**king point of wifi if you have to sit on the router
I know it's not ideal and the laptop should function as is, but if worst comes to worst, you can get a netgear USB wireless adaptor. I used to use one on my desktop cause couldn't run cable from my room to router. Worked flawlessly, even playing games.
Most people on here don't know what they are talking about, when you have people like Hamish recommending laptops there's something wrong haha
Should have stayed with Asus. Guarantee within 6 months you'll start having overheating issues and things like the fans will begin to fail. I would see if you can take it back, you should not have to use an external card on a device that's meant to be portable...
Oh and I know Hamish is going to quote this but... if you had similar issues on a MBP you could take it to the Apple store and get a new replacement the same day haha
Yeah but you have to make an appointment to speak to one of those arrogant, cocky, shitty joke making hipsters aka a "genius" and frankly I'd rather eat my laptop after taking a shit on it
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
