Jack from Citywide towing on 0419877437
towed most of the SAu motorsport ppl at some point, plus grant a couple times.
used to do a bunch of track days in his 33 gtr so he know how to get them on and off the tray.
only issue is when he tries to buy the car off you, eh grant....
Well, he didn't talk me into selling it to him.
I offered it to him and agreement was done that day.
i know, he doesnt even have a second job or a kid.
lol
I do drive to Norfside everyday and that's not even far.
Try living in Frangers and work in Williamstown and tell me that it isn't that far.
Do this 1000%. Get out of the northern suburbs
This.
Living in the norfside is bad for you.
Can't f**king believe I lived in Epping for 12 months... And still can't f**king believe the R wasn't stolen for whole time I had it while living up there.
No just get out there and try some new shit, new hobbies etc.
This, avoid expensive hobbies.
Before you ask, I haven't able to find cheap hobbies I like doing...
lol
how about live Williamson, and work, pretty well anywhere else in the world....
where did you work in willy?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
