Yeah I've got two new O2 sensors. Car has always been a pig to drive until it got to about 1/5th on the water temp gauge then all of a sudden it goes into a different map and drives as if its come onto boost. Did it on standard ecu and now Nistune. So I'm a little concerned it might be the very expensive ignitor as most other things have been changed. Still makes a lot of power though :\ Realistically haven't got much different fuel economy from Tuned E85 to stock ECU on 98/100. So somethings definitely causing fuel to get raped in the first 5 minutes of driving more than it should..
Edit: To clarify I'm managing about 250kms daily driving, probably could get more but I'm not keen on finding out how fast the last bit of E85 disappears. This seems pretty low to me considering I don't thrash it at all.
Coolant temp sensor all good? What temperature range plugs are you running? Stock coils?
Well I got a second hand one with the car when I bought it so I'm gonna assume he changed it for a new one (coolant temp sensor).
New BKR6E gapped to .08
Splitfire coilpacks
New coilpack loom
AFMs just changed for another set
O2s new
Racepace use BKR plugs over BCPR or that your choice?
You might be right, truth be told it was just what came off the top of my head. Now I'm not sure which one. Regardless though whichever one it is its worked on countless cars so it SHOULD be fine in mine, it's the right plug for RB and E85 anyway..
Yeah just did some looking up on that and you're right. Shouldn't be the problem really and I'm pretty sure its BKR6E that we use not BCPR6E.
Looks like I'm going to have to just keep throwing parts at it, hard one to diagnose on the dyno as you have to leave it on overnight, check it in the morning on a cold engine and you have to know what sensors SHOULD be doing what at what temperature, and hope that you notice one of them change suddenly and more drastically. Even though all the other ones will change at the same time too.
can go past dat 3rd gear overtake move @ 80
It is good and that's what I do with my rolling drags, dropping to 3rd at 80 is actually my favourite move! Closely followed by 2nd at 50 when approaching lights and they turn from red to green...
lol my friend used to drop to second at 80
You're gonna hate -9s on a 2.6 then! Had some kid try to be hektik in his stock GTST giving those little pulls next to me today at 80kmh. I geared down to 3rd and put the foot down, I basically just coasted away making small amounts of boost, it wasn't very impressive I must admit. That's with -7s as well!
they both work, it's just the BCP have a ~2mm longer electrode and contact slightly better
BKR wouldn't cause the issues, I was just curious
For this reason I use BCP...my coilpack springs are a bit short and I had random non firing cylinder issues
How much power you running?
May have to swap for -5s, but I love response and will take it over outright power any day
Also winning is winning haha
Speaking of, very easily dispatched of an Evo 8 off the line today...where he really should have got me...instead he got bogged down off the line and if that happens it's all over for a 2 litre turbo AWD
Do crashes necessitate a write off or can be a minor incident?
Thefts:
Ric
Borci
Birds
Tony
Alvin
Crashes:
Hamish's m8
Do bikes count? had 2 stolen :(
Forgot I wrote off a 33 when I was 18 as well lol.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
