Dezz to the left of me, Ric and Alex to the right
Here I am
Stuck in the middle with Hamish
Don't think people didn't notice you calling Dezz a clown, and Ric & Alex Jokers
Unless the centre is 60kms to the left hamish is not located in the centre.
I suspect he votes greens.
Christ no... I work in a bank dude
Hamish is so left the Greens vote for him
FKN LOL
Just for everyone's entertainment, I went back to the 2013 Fed Election Vote Compass...
It's roughly what i would have expected....
Now I wanna see Alex's results (if the chart goes that far)
Dezz when you went to Broadford is there a few different track layouts?
Ended up getting some leather pants too figured may as well if I get into it a bit.
Got PI on Sep 11 too
thats racist.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
