Basket of Goods 11) Products in the “Basket of Goods” attract a $30 rebate when $100 or more is spent on eligible products. To receive the $30 rebate for the “Basket of Goods”, singular or multiple receipts must total $100 or more. One rebate is available per eligible customer per calendar year. The eligible basket of goods products are: • Mulch (organic, pebbles, scoria and other similar ground cover) • Flow Control Valve / Tap Flow Reduction Device • Wetting/Moisture Agent • Compost/Mulch Bin • Soil Moisture/Rain Sensor • Garden Tap Timer • Drip Watering System/Weep Hose • Trigger Nozzle • Temporary Greywater Diverter • Shower Timer • Waterless Car Wash • Rainwater Diverter • Flow Interrupter for Toilet
Bam, can claim $30 off that shit easily...
...if only I kept receipts for my mulch and my waterless car wash spray, cause you never know when you might need to return those products
Cunts
Labor were no better for what it's worth ol mate swan took a private flight to afl grand final @ $12k apparently
All crooks.
This. I Don't think LNP can be held accountable for BB here. TA can't be on top of everyone's spending, it's impossible.
They are going through all her expenses atm and the bitch has spent $800k in the last financial year on top of her $350k salary.
Even back when her, TA and JH were all just cabinet ministers, across a 4 year period TA and JH spent approx $20k each on chartered flights, BB spent $130k.
Al is right though.. Labor's expenses are exactly the same.
Aparently the age of entitlement is well and truly NOT over
Like I've always said all politicians are cocksuckers, you just vote for the cocksuckers that are going to f**k you over personally the least.
But old mate Abbott made a big deal over $900 of cab charges, but 90k is all good. Sorry, $88k.
dude I walk through the docklands at 7am...
Oh the humanity
f**king LOL ot Shorten trailing Abbot in preferred PM polls.
How the f**k ANYONE could fail to capitalise on Abbott's epic clusterf**k of a first year is beyond me...
Honestly if he bins this it will be more of a f**kup than Hewson in 93...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
