Congrats Tob!
The problem with me is that i think i need a gym buddy, used to have one until i changed gym. Find it harder to push myself further going solo.
Protein shake twice a day? Is this like everyday?
Aren't no body got money like that!
Currently trying Gold Standard- double rich chocolate. Not bad imo.
Pm me? There might be hundred ways but I'm curious of the Bird's way. :)
Gym buddy is helpful, but not needed - best thing about a gym buddy is you have a spotter so you can push to the absolute limit, you can always ask someone else that's there though if you need a spot.
Yeh try to twice a day every day, but in reality its usually once to be honest
Congrats Tony! =)
In other news, I know theres suits fans here... season finale thoughts anyone? Although perhaps should be spoiler free somehow in case peeps haven't gotten around to seeing it !
I've never had a gym buddy and I've been going to gym for around 10 years. Only thing that sucks is not having one for bench.
I don't think you need to take a protein shake twice a day.
Yeah I agree mainly just bench, and wow 10 years that's dedication right there!
Protein is gooood though
well it's a supplement if your diet is correct you shouldn't need protein shakes. You may still take them but shouldn't need them
This is what i've always been going by, prefer to get my protein from food rather than replacing them with protein shakes. Depends how your work out is though i suppose, sometimes food just isn't enough.
Correct me if I'm wrong. :)
You're all correct...if you're getting enough protein from your diet then you don't need shakes, animals are enough. If you're lacking in protein, then you can have a shake as many times as you want to meet your dairy requirements.
You can also just drink a shitload of milk, hence the gallon of milk a day (GOMAD) diet.
Did a liter of blended milk/protein/banana/weekbix a day for like 4days. Lost 5kg wasn't fun at all!
Wasn't by choice as I could only intake liquid for those few days...
I remember reading up a bit on how much protein you need if you're bodybuilding, think the general rule is 1gram per pound of body weight, so 165grams for me which is hard to get just off food alone.
depends what your goals are and activity level i guess
Edited by UNR33L
Should have added those extra 3L a day
thought it was ~1g/lbm (so just %muscle lb) :P
lol my mate just texted me about it, says the new rims cost 2x what the car cost... standard yo dawg i hear...
Yeh you can calculate it into lean mass like this :
http://www.musclehack.com/how-much-protein-is-needed-to-build-muscle/
Still ends up roughly the same as "1gram of protein for every pound of overall body weight"
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
