stock BCNR33 is a round 160/170 rwkw
dont forget its rear wheel drive until the system detects traction loss
so technically its a rear wheel drive car until loss of traction
its not like an evo where its always all wheel drive with adjustable split
Found this in the dyno thread:
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page__view__findpost__p__5448314
1995 R33 GTR - 110,000KMS
Stock everything except splitfire coilpacks.
stock boost.
193.4awkw
Every dyno is different but interesting none the less.
Why are you both calculating it as rwkw instead of awkw, since a gtr is 4 wheels?
Cause most dynos are RWD and I think the GTR boys usually pull their front driveshaft for tuning/runs.
Figure sounds too high, either happy dyno or he has an exhaust / aftermarket cooler / boost tee. The factory flywheel kw was supposed to be 206kw, but more realistically ~220ish which is around 160-170rwkw.
Ok found another one, close enough to stock
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/page__view__findpost__p__5121848
1995 R33 GTR
107xxxkms
kakimoto catback
everything else stock!!
First run in red was with boost restrictor pill still in place!!! About 170atwkw
Second run removed, 30atwkw increase pretty good in my opinion!!!!
30awkw increase by removing the boost restrictor! What are you waiting for Grant?
I got 233rwkw with just an exhaust / boost restrictor removed / cam gears @ racepace dyno (stock ecu)
GTR was just fail to get to work in imo, maybe I'm soft but thats pretty much all it got used for haha
Money.
For pair of steel wheeled turbos, PFC, injectors, afm, exhaust, labour money to fit these plus nismo clutch I've got sitting in garage for a while.
And many more things such as swaybars, arms, tyres for the rims, alignment, hicas lock bar.
It doesn't end!
ok the lease rules are oldest model allowed is 2007/2008
only found evo ix 07 which is like 40k pfft
where is nick he will know of a 2007 IX for cheap
Just a question Paul. Why Evo?
Doesn't that feel like you're downgrading from a superior 6 cylinder to a inferior 4 pot?
No offence to Nick :P
Guest
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
