Hi,
I'm not sure if this should go here or in the General Maintenance Section but;
Today when I was driving to work, I started to drive up a hill and my Turbo's wouldn't engage. I looked out the rear mirror and the car wasn't blowing any smoke to indicate shagged Turbo's.
I thought it might have been the AFMs, but the last time I had an AFM die on me in the GTR the car would refuse to go above 4K rev's (Same thing with my old WRX) and a light would 'activate' on the dash on the right hand side (In the 4-cluster where the AWD light is) and it would just bog down when I tried to accelerate. This isn't happening this time.
However, as it is now, I can drive the car normally, it rev's out to 7K and feels like I'm driving an N/A car. The car just refuses to boost and on the standard 32 GTR 'boost' display it stops just before hitting 0. I can hear the Pod Filters sucking in a minute amount of air, but there's no blow-back when I take my foot off the accelerator.
Is there any way I can tell if this is an AFM, Turbo, ECU or Pod Filter without having to buy new parts? Obviously there's the standard "Take it to a Doctor" response, but if it's something simple that I could do myself, I'd rather do that, than take it to someone and have them waste their time on it being something simple.
Also, is there a possibility it could be the exhaust somehow? I noticed on the drive home that the exhaust sounded different to normal, can't really explain how it sounded different, I just know that it did.
Thanks in advance for any help provided :)
https://www.sau.com.au/forums/topic/380589-1991-r32-gtr-turbos-stopped-working/
This happened to me.
My cat was totallllllllllllllllllllllly blocked (imploded after a run with an Evo..). Drop the exhaust before the cat and go for a quick drive - see if you get boost back :)
Edited by 10 4
The cat temp light will come on when the exhaust temp is too high and may damage your cat.
It doesnt know if your cat is stuffed.
Drop the exhaust and check the cat, and hope you don't find the turbine wheel in there too.
@Don: No, nothing out of the ordinary, one minute I had boost, next minute I didn't. And I'm running 5 pounds of boost (Which is the stock tuning I believe)
@Everyone else: Thanks for the help, I'll get it down to an exhaust place Thurs or Fri. It's probably time I thought about putting on a new exhaust anyway... Car is still stock standard ;)
Check that the wastegates haven't stuck open and are causing the turbos to not spool. As said above as well check that the cooler piping isn't split and that the cat isn't blocked.
The next step is to drop the exhaust off the back of the turbos and as said check that the exhaust wheels are still there.
Best of luck
I'm going to try and take it down to an exhaust place tomorrow and see if they can pull it off to have a look.
At least that way, I should be able to narrow down the problem.
I'd find it a little weird if it was the Turbo's themselves that had exploded/dropped parts, as there was literally no noise (Bangs, clunks, clangs, tingles, etc) when they stopped working. If they had dropped parts, I would probably have smoke out the exhaust as well, as it is... There's no smoke coming out at all.
I did manage to figure out how the exhaust sounded different though... It sounds strangled and muffled compared to normal... So that would say that there's some form of blockage. Fingers crossed this is an easy fix :)
And thanks to everyone for the help :)
Boost leak = black smoke
Broken turbo(s) = no boost at all, rough running when you try to put the motor into the conditions that would used to have made boost. No black smoke IIRC, and they can go with no/little noise.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
