Nsw Whoretown/wasteland, Want To Bitch About The Police/government Doing Their Job?
  • Replies 138
f**k me it's a sad day when I'm the first on topic.
http://www.theaustra...x-1226171783664
Commonwealth ombudsmen resigns over collaborating with the greens
Do as Bob Brown says not as Bob Brown (technically sarah hansen-young) does
at least he admitted he was wrong, i was watching the agenda (on sky), they had one liberal and one labor senator on and the bitching was just.....pathetic really.
To all you kids who want a whore thread, the best whore thread is the hidden whore thread.
If you want access to it (And more goodies) then pay your $60 Member ship fee, send in the bit of paper, and you'll have access... ;)
not really worth it IMO... been there done that.... like i wrote ... that's just MY opinion :whistling:
I dunno, I like saving money...
$60 to join, and about $100 off insurance dependin on everything... Just for that I say it's worth it... But then again, that'd just my opinion...
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
