  • Replies 70
Ouch man looks nasty. Id pull number 5 out and look at getting another piston. That is depending on bore condition of course. Looking at that engine for 500kms it seems to have a lot of carbon build up? Dunno could be the pictures though.
So just to clarify, the cam gear retarded itself some how, but if the belt was to jump a tooth or ten it would advance the cam would it not? Just trying to get my head around it
Yes my thinking too re carbon buildup
fark ... mate if i have any parts u need u can have em free of charge. any way i can help out i will. i have a1 cond rb26 pistons, rods, bearings head and main bolts. heaps of other sht aswell just ask :(
Thanks heaps mate for the offer, I'm just trying think about what I wanna do with this, just got myself a nice daily, so atleast I can get too work now,
The head itself looks pretty mangled in the combustion chamber, so will need to get some local opinion before I consider moving forward again
Depends which way it skips mate. But more then likely it would skip a tooth following the direction of rotation (clockwise from the front) which would mean retardation of which ever cam skipped. On your engine obviously this is intake. Yeah i would be concerened if that carbon is more then a couple though. See if it rubs of with your finger.
if your after some free advice without any obligations drop into harriss engines in ossie park, old guy there is very helpful and loves a chat.
Well I got the sump and ati, just need a stocker motor,
Gerg: got the valves off a forum member on here, brand new but only got valves they was cheaper then Nissan replacements, doesn't look like any det,
Dori: just weighing up what to do, def no plans for this until the new year tho,
Edited by ahh 33 s2
butters/zeroyon who is on here and antilag runs that exact set up on his drag S13 (which runs 9's) and around 550rwhp for a few years which is more than needed for a RWD
Considering the cost it's not a bad option :)
Edited by SimonR32
Good to hear. I was going to say relying/using this car as a daily seems a bit much. Get a nice cheap daily and take all the pressure off having it driveable all the time.
I feel ya pain though, hopefully its an easy road back to running again.
Its been said, and I will say it again.
Stock motor and whack on your uprated peripherals.
Go hard. Get some joy out of it. Dont worry if you pop the stocky.
Agreed !
Well no real updates but after a call from Paul from red R racing, for all u haters he not that hard to get a hold of, just wait for him to call you, haha, but told me to check the cam caps to make sure that they were installed in the right way, because if they put on the wrong way they will wear on the cam and cause it to bind up, and make the belt jump, unfortunately that was too no avail, but a big thanks to Paul for making the effort to contact me and trying to shed some extra light on the matter.
Which still means unfortunately that apart from some massive timing issue I don't really now what caused the timing issue or the belt to jump,
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
